Removing the heads - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 12-18-2007, 11:31 AM
Send a message via Yahoo to jwindbigler
Removing the heads
I am about to pull out the engine in my 89 F250, (due to a blown engine) and I need to pull off the heads, but when I look at the bolts, they look like they have a 12 point bolt in them. Can I use a regular socket on the bolts, or do I need to buy a socket from ford to remove them?? Also, is there anything that I would need to know about removing the crank? I want to get the internals of the engine tested, and I just wanted to know if there was some tool, or some trick that there was out there to make it easier (besides for paying someone else to do it). Thanks
Old 12-18-2007, 02:40 PM
Gun Nut
Hopefully someone can help you - I've never taken any off on one of these beasts.
Old 12-18-2007, 02:56 PM
ADMIN AND TECH
im not absolutely sure but if im not mistaken the heads bolts are 5/8 in size and a regular socket , no special socket is required, , as far as removing the crank , all the connecting rods need to be loose . then the main bearing caps, the front engine cover and harmonic balancer and rear main seal cover will all have to be removed to get crank out
Old 12-18-2007, 03:01 PM
Gun Nut
Alright what have you done with the REAL Scott?
Old 12-18-2007, 03:05 PM
Thanks. I really appreciate it.
Old 12-18-2007, 03:23 PM
ADMIN AND TECH
hey i cant be right all the time
Old 12-18-2007, 03:27 PM
when in the last hour did you finally realize that???:fawkdance:
Old 12-18-2007, 03:32 PM
ADMIN AND TECH
hold on let me rephrase that comment then, if i let everybody know im always right , then that wouldnt leave anything for you to do marc :fawkdance:back at ya
Old 12-18-2007, 03:34 PM
:fawkdance: :fawkdance: :fawkdance:
Old 12-25-2007, 09:13 AM
A regular 12 point socket or box end wrench will fit just fine.
