| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
blinkers dont work??
the blinkers on my 89 stoped working.the fuse is good and the relay seems to be good.anyone have any ideas what could be wrong....switch maybe?can i test it without pulling the colum apart?thanks
joe, |
turn the key back a little after you start the truck. let me know what that does. and
to the org.
coming back into town tomorrow ill check that.thanks for your imput.
joe, |
my 81 and 82 broncos turn signals wouldnt work unless the key was turned back to the stop. :thumbsup: hope that helps. if not change the "blinker". its on the fuse panel and looks like a aluminum pop botle cap. it unplugs like a fuse and should cost about 6 bucks at the local parts store.
tryed the key thing...no luck,so ill prob go to the parts store tomorrow and get a new "blinker".ill keep yall updated.thanks for the help.
If all the blinkers quit it is ussually the flasher that plugs in the fuse box, lets hope so its a cheap easy fix
I figured turning the key back was worth a shot. thats what was wrong with my 80's fords. my 96 powerjoke the blinkers quit and it was the. "flasher" that should getcha hooked up. |
fixxed the blinkers.switch in the colum was no good.
