| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
Flywheel problem
has anyone heard of or had there flywheel or torque converter come loose on the idi truck? if so can you describe what i should be lookin for and if it makes a grinding noise at the back of the motor until you rev the engine a little
If the torque converter nuts backed off the torque converter studs, the most likely thing that would happen is that the studs would break off. what kind of noise are you hearing? maybe the bendix on the starter is sticking and grinding on the teeth on the flex plate. just an opinion
the noise sounds like when the fan hits the fan shroud. sounds like a loud grinding, only happens at idle once you hit the gas a little it goes away
is it only when you first crank it?
no it has that sound the whole time you sit at idle anywhere
found out the problem.......to giant cracks in the flywheel
dang man i hate to hear that.
