98 E350 7.3 WONT START - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 06-06-2012, 04:16 PM
Need help I got a 98 7.3 wont start.checked all fuse unplucged fie heater and water in fuel sensor.still wont start. My scanner will not read.maybe bad pcm?
Old 06-14-2012, 05:22 PM
check your glow plugs and crack fuel lines to see if you getting fuel does it crank and just wont start or completely dead
Old 06-15-2012, 02:42 AM
It turns over fine I manually but still won't start it recently had new pump I have pressure at shredder valve.any ideas any help is appreciated
Old 07-10-2012, 03:55 PM
pump could be slightly out of timing see if it willl crank with a rag soaked in gasoline in air breather
