Swapping 2wd to 4wd? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 8 Old 05-16-2012, 07:51 AM Thread Starter
KY Bow Hunter's Avatar
I need some advice. I have a 1990 F250 with a 7.3 idi non turbo. Its problem is that it's only 2 wheel drive. I want to convert it to 4x4. Is this a expensive task? Also roughly what would it run me for the parts? My plan is to make it a farm truck that will last forever and still have the ability to tow equipment and go anywhere. I plan to do it all my self. It will have a flatbed and be slightly lifted.*
OR...*Would it be smarter to just sell this one and buy a 4x4 then do the things that I wanna do
2008 F350 CCLB, Deleted & leveled, normal upgrades
SOLD---96' Ext Cab, Longbed, 7.3, Single 6in Black Miter Cut Stack, 325/65/18 Goodyear Wrangler Duratracs on Black 18in Procomps
SOLD---08' Crew Cab, Longbed, 6.4, Spartan V4, 4in Turbo back exhaust, DPF Deleted, AFE Stage 2 intake, 4in procomp lift, 20's and 37in Mud Grapplers
KY Bow Hunter is offline
post #2 of 8 Old 05-16-2012, 09:21 PM
JSchuricht's Avatar
Start looking for a wrecked truck to pull parts from. I am not familiar with a 90 2wd front axle, if it's leaf sprung it should be fairly easy. The most expensive parts will be the axle, transmission and transfercase. The Dana 60 I just bought for my 95 was $900, you can occasionally find a better price but a higher price isn't uncommon either. You will need to shorten the drive shaft and replace the transmission with a 4x4 unit. If your not doing anything too extreme, I would just get some good tires and a locker.
JSchuricht is offline
post #3 of 8 Old 05-17-2012, 02:14 AM Thread Starter
Yeah I thought about that last night. I think that a good set of mud tires and possibly a locker will be the way I go. Im not a big fan of not havin 4wd but that might work for me
post #4 of 8 Old 05-24-2012, 07:47 AM Thread Starter
What difficulty level is this swap? How much do you think it will cost me total?
post #5 of 8 Old 05-27-2012, 08:46 AM Thread Starter
Has anyone done this swap?
post #6 of 8 Old 06-30-2012, 07:16 AM
It will be hard considering you will have to actually get a front end swapped in thats geared the same as your rear. Replace the shaft in the transmission that goes into the tailshaft i belive 2wd one are 2 inches shorter then a 4wd. All that being said, its prolly cheaper and less of a pain to just go to a junkyard and get a Transfercase and front end. I did this swap one time on a 94 f150 i had and it bout drove me to drinking... Lol
Strokiniton38 is offline
post #7 of 8 Old 06-30-2012, 07:23 AM
atvrider93's Avatar
Quoted: 8 Post(s)
You have to either swap the output shaft in the Trans or find a 4x4 Trans. Then the transfercase, then the front axle. your best bet would be to find a wrecked truck. You're probably looking at about 2000
Sent from my DROID BIONIC against my will
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #8 of 8 Old 07-21-2012, 06:00 PM Thread Starter
Ok so I ended up selling the 2wd. I am just gonna look for a 4wd one and avoid the surgery!
