Oil cooler - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 04-17-2012, 03:01 PM
Oil cooler
Anyone replaced an oil cooler in a 7.3l Idi? Got quoted 1200 and no way do I have that or will ver put that much in this truck! Just wondering how hard of a job it is. I have another truck to drive but I was hoping I could sell the ford and get a nicer vehicle nd use that as a down payment but can't do that now
Old 06-14-2012, 05:27 PM
1200 is super high they are easy to replace i think its 4 or 6 bolts drain coolant remove bolts the whole cooler comes out remove ends install new o-rings now the tricky part is you will have to press the ends back on because of tight fit but other than that its super easy 1200 no no good luck
Old 06-14-2012, 05:30 PM
Is it basically the same as a DIT 7.3?
Old 06-22-2012, 01:23 PM
I think you can get the center section for $400 from the dealer
