| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
fuel tank selector valve
i need a to know what valve to get a 6 port or a 3 port? and whats the differance??
If you have a powerstroke diesel with two tanks, you typically need a 6 port valve. Look under your truck at the selector valve. If it has two input tubes and one output tube, you need a 3 port valve. If it has 4 input tubes and 2 output tubes, you need a 6 port valve. On the 6 port valve, you have a fuel tube and a return tube for each tank and a fuel tube and a return tube going to the fuel pump on the engine. Check your existing selection valve.
THANKS!!! Bittracker1 |
