engine problems - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 09-07-2007, 05:46 PM
engine problems
i dont know what im doing never been to this place but i need some help. i got a 92 F-250 7.3L banks turbo charged and any time it gets a load like when i turn the wheel all the way to the left or right the engine will die at start up it will fire then it will just die and while i am driving and i let off the throttle it will die...i thought it might of been water in the fuel but im thinking something might be clogged or i need new injectors but i have no clue and im getting ready to say screw and give it back to my parents and let them deal with it
Old 09-07-2007, 05:55 PM
Desert Shield/Storm Vet
Moved your post might see more action here. First off to Powerstroke.org. When is the last time you changed the fuel filter?
Old 09-07-2007, 05:59 PM
i changed it just today and no change thats why im thinking something might be clogged
Old 09-07-2007, 06:42 PM
ADMIN AND TECH
you can bump the idle up on this truck, but more than likely you have a injection pump acting up, run a fuel pressure test just to make sure you dont have any base fuel pressure issues
Old 09-08-2007, 12:10 AM
yeah alright but a i have no idea how to do it i dont even have a presssure tester...but what if its not the injection pump but more than likely is what else could be the problem?
Old 09-08-2007, 12:13 AM
is their a auto zone near by you they have free tool rental and they have a fuel pressure tester.
Old 09-08-2007, 04:31 AM
What is the base idle RPM? It should say on the engine or door frame on a sticker what the idle RPM should be. I believe my 94 F-350 IDI diesel is 550 +/- 100 RPM's. Maybe it's just too low...
Old 09-08-2007, 04:40 AM
ADMIN AND TECH
if you dont know how to do it , you might have to take it somewhere to get that done , and i like mine to idle around 700
