Help...Brother just blew up his 7.3 1988F350 - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 09-05-2007, 08:56 AM
Does anyone know of somewhere we can replace the 7.3 out of a 1988 F350....motor is blown and we need a replacement. Can you put a newer gen turbo 7.3 in the truck or would that be a waste
Any help, let me know so I can help him get this old motor out and a new one in.....
thanks
Old 09-05-2007, 11:41 AM
im fat and ugly
bump for ya
Old 09-06-2007, 04:23 AM
I tried to put a 99 in an 89, it can be done, but its a huge job. I ended up just buying a remaned long block. You would need to moddify some of the electronics, and the flywheel on the newer engine is a 13 in. instead of the 11 or 12 used on the older models. may have a problem with a torque converter too. the crankshaft hub on the old engine is a 9 bolt, on the newer engines it is a 10 bolt.
the input shaft on a ZF 5 is also smaller than the shaft on a ZF 6 so you may need to mahine the shaft or change the tranny if its a standard
good luck
-Peter
Old 09-07-2007, 09:12 AM
BIG TRUCK, SMALL DRIVER
thanks
You will be better off sticking with the IDI if all you want is a replacement. Several things are different between the blocks, and the heads will not work at all. If you want to upgrade to a PSD, it will bolt in, but many things will have to be changed. You would want an entire parts truck to rob.
