| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
HELP! fuel leak
not my truck. customer of mine. 1993 f350 7.3 idi factory turbo vin code c. there is a fuel leak on top of the filter housing around a 2 wire sensor or something. i need help identifying what it is and if i can fix it. i can take a pic if that helps
i guess its only 1 wire. its right on top of the filter housing
fixed. that is the fuel heater. pulled the filter (was the wrong filter anyway) took it apart and it has a o-ring that was all hard and cracked. replaced the o-ring. put it all back together and it seems to be all back to normal
Thanks Chevy Joe
Will an o-ring fit from a standard o-ring kit or will I need a special one. After you remove the filter how do you take apart the part with the wire? My truck 90 F350 7.3 auto I bought new. I Still drive everyday. Thanks. loadmaster3 |
