HELP!! 7.3 IDI REVS, POPS, AND MISSES - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 10-16-2011, 02:45 PM
93 factory turbo. 180k miles. truck ran fine the night before....next it started this right upon start up. they are new injectors..is it possible they were bad?
bad injectors? 7.3 idi turbo - YouTube
Old 10-16-2011, 02:47 PM
i cracked all the injector lines and they are all getting fuel...it is a newer injection pump as welll...im stumped. the truck has NO blow by. and barely smoke...when it pops/misses a light puff of black smoke will come out
Old 10-16-2011, 02:50 PM
the injectors are 3-4 months old and have been fine the whole time
Old 10-16-2011, 03:02 PM
The Tamed Racing Driver
You might have one dribbling. Take them out and have them pop tested.
Old 10-16-2011, 03:05 PM
hopefully it is just an injector issue. is that what it sounds like to you?
Old 10-16-2011, 03:08 PM
Where did you get them from. I could see a dribbling injector making that noise.
Old 10-19-2011, 11:38 AM
injectors tested out good
im lost.....could the IP be bad causing this?
Old 10-20-2011, 04:09 PM
took the IP in for testing today. they took the cover off and found metal shaving. they said a retainer ring had came apart. pump is getting rebuilt tomorrow. all should be good!
