| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
Gentlemen, why would a '94 turbo 7.3 with reconditioned inj.'s and 180K get 8 to 9 mpg empty, when my 84 6.9 with 289K got about 11 towing a 16 foot enclosed trailer. One garage says its about all I can expect, another wants to do a compression check. I had the timing checked and he says he turned it way up. One guy on this page claims 16 to 17 mpg. what's the deal???
Welcome!!
Bumping this back up for ya!! Someone should be along soon to help you out! |
Does it smoke? Was the timing turned up to specs or just played with? Also, are the air and fuel filters in good shape?
If you're thinking the pump has been turned up alot, I would doubt that. The guy I bought it from just didn't seem like a tinkerer- everything on it is stock. It has good power, but it only smokes a little when I get on it, which is a lot less than my '84 6.9. Seems to me the mechanic only played with the timing seeing as he only charged $60.00. I changed the air filter before bringing it in, but you can be sure I am changing the fuel filter this weekend. Thanks for the input!
my 94 PSD gets 20/22 on the open road, (me nad dog in it)15 towing !! I dont understand how the injectors woul do it but who am i Bill
With 180k miles, I would think the drivetrain is not as free rolling as it was new. I would go through and change the gear fluids and make sure I hit every grease point I could find. Also take a look at the wheel bearings, pick up each front wheel one at a time and spin the tire to see if you hear a slight grinding noise.
Is it 2wd or 4wd? How are the tires? Are they aligned good, does it track straight? Exhaust leak? Many different things will cause bad gas mileage. |
It's a 4x4, so I wasn't expecting miraculous mileage, and the rear tires have worn suspiciously worse than the front, though I've only owned the truck for two months. The prev. owner could have put the nice meats on the front. He used it for towing a fifth wheel which could explain rear tire wear, too. I am planning on changing the 33 x 12.5's on it now to 275 8.5 street radials. No exhaust leak either. Thanks for the tip on the drive train.
injection timing plays a big part i fuel mileage on that engine
OK guy's: I have ne of these 94 powerstroks ,the thumbnail is up in hte left corner. I get 22 mpg on the I state with me an the dog.. I pull a 36' Montaniana 5th wheel i get anywhere from 13 to 15 mpg (which way is the wind blowing), I got 12 mpg while on I44 across the Ozarks. While driving around town (joliet ,IL) i get 15 mpg.. I have kept records and am sure of this.. The truck has 4' exh,K&N, So Bend con"O" Clutch, Edge evo, coolant filter, and the blue CPS from.International.... BILL>>>>>>>>
