fuel filter housing leaks - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 2 Old 08-19-2007, 04:29 AM Thread Starter
I have a 92 7.3 F250 with fuel leaking underneath of the fuel filter housing. Would anyone have a idea of what a good fix would be.
dfred is offline
post #2 of 2 Old 08-19-2007, 05:15 AM
ADMIN AND TECH
SCUFFY828's Avatar
the o-ring that goes on the bottom of the filter could be bad , if it was mine , i would go buy me a good filter not a cheap after market and replaced filter , during replacement , make sure the lower housing isnt cracked or pitted out from corrosion and if not put back together and see what happens , the drain is also on that lower housing , make sure it tight
ITS STOCK
SCUFFY828 is offline
