| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
turbo kit for 7.3 idi
i'm sure it has been talked about on here but i havent really found anything, i was wondering if a stock 7.3 idi non turbo can handle the turbo kits or what problems if any they have had any
A stock 7.3L factory N/A can hadle a turbo as long as you don't over boost. if you get a turbo that is wastegated then meake sure the boost doesn't go past "x" psi. sorry i don't know what psi the n/a engine is rated at. It does depend on the condition of the engine as well. if the engine is near the end of its life then no point in puting a turbo on it.
thanks, i just wasnt sure if you needed to put head studs,of if the pistons and lower end can handle the boost
from what ive been reading no more than 10 to 15 lbs of boost on the stock idi any more than that an you will need to do some engine mods ...ive been thinking about it to so doing alot of reading on it
it can definately be done you just have to compensate for how powerful your turbo is by modifying your engine to handle the abuse. im researching the same thing as i just got an amazing deal on this huge turbo for my f350. im not getting a kit though the whole setup is going to be custom. also studding the head is one way to compensate.
