7.3 IDI Fuel Pump Adjustment - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 06-22-2011, 02:38 PM
Robby
So I have a 7.3 IDI. I went to go adjust the fuel pump and just couldnt get the adjusment screw to turn at all. I tried everything. I even cut a allen wrench and stuck it in a socket for maximum torque. Any ideas?
Old 06-22-2011, 07:05 PM
Send a message via AIM to FORDF35073PSD
I'm assuming you are talking about the screw on the back of the pump, might be a dumb question but were you able to break the jamb nut free?
Old 06-22-2011, 07:20 PM
Robby
Idk what that is honestly. All I did was put the truck in neutral. Un bolt the little plate. Rotate the crank til the allen key screw in the fuel pump was visible. And try to turn it. Am I missing a key point?
Old 06-26-2011, 01:08 PM
I had the same problem when I did mine .. what I did was found an Allen wrench that was long enough for me to place it in the Allen screw in the pump and had enough sticking out of the pump then I grabed a pair of handy dandy vise grips and placed them as close to the side of the pump and tightened the piss out of them and I was finally able to turn it ...... once you've adjusted it once it becomes a little easier
