7.3 idi aftermarket turbo? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 06-05-2011, 07:06 PM
How well will a N/A 7.3 idi hold up with the turbo from a factory turbo idi? Will there be any problems if I put the turbo on the N/A? Maybe there are no differences from the factory but just thought I should check
Old 06-26-2011, 01:36 PM
I've asked the same question many times ... what I've found out it is that it bolts right in if you can find a donor truck with the whole system intact and adjust the IP to get the air:fuel ratio in the sweet spot and the pcm on the auto trans for the tidi is different but not to sure on that part
