Glow Plug Help!! - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 04-26-2011, 01:01 PM
Glow Plug Help!!
HEY GUYS NEW TO THE DIESEL WORLD HERE
I JUST BOUGHT A 1989 FORD F250 7.3 IDI, 4X4, 33'S, 5SPEED, 79XXX ORIGINAL MILES...
IT DOES HAVE ITS FAIR SHARE OF LITTLE PROBLEMS THAT NEED TINKERED WITH BUT I'M WILLING TO FORK OUT A LITTLE MONEY TO HAVE THEM FIXED AS TIME GOES ON...I'M HAVING A LITTLE STARTING PROBLEM...I JUST HAD MY BATTERIES CHECKED AT WALMART AND THEY CAME OUT GOOD. TRUCK'S GOT A BRAND NEW ALTERNATOR, STARTER, GLOW PLUG RELAY ALL THAT GOOD STUFF AND THE TRUCK STARTS UP PERFECT WHEN SHE'S PLUGGED IN BUT WHEN SHE'S NOT SHE IS A BI$$H TO START...SO MY QUESTION IS I'M WONDERING IF IT'S MY GLOW PLUGS???
I FOUND THESE ON EBAY AND WONDERING IF THESE WOULD DO ME GOOD??
http://cgi.ebay.com/ebaymotors/Glow-...item2a0f26cd71
THANKS FOR ANY ADVICE!!
Old 04-26-2011, 10:05 PM
Well I've got a 99 F350 with the same engine and had to do lots of cranking to get it going. Took it to the local expert and they replaced 4 glow plugs (3 on one side and 1 on the other). Started and ran great afterward. Just a note here -- if you are paying someone to do the work -- have all the glow plugs replaced while they have the valve covers off. They are not that expensive compared to the labor to replace one.
Old 04-27-2011, 11:56 AM
could i change the plugs myself?
Old 04-27-2011, 05:26 PM
I suppose you could but I didn't see it done so can't say how difficult is was. I had bought 2 glow plugs from NAPA when I took it in and they installed 2 and used my 2 also. Good guys -- most repair shops wouldn't use parts that you bought.
Old 07-05-2011, 06:02 AM
he has an IDI, the glow plugs are not even close to the valve covers.
Old 07-19-2011, 11:28 PM
So your glow plugs are in the intake manifold! on top of the motor much like spark plugs!!!! Jst went through this with my 93 7.3L! did them myself took 35 - 40 min! Go down to your local parts store and by them!!!!! Just make sure that when you pull them out do it gently you dont want to break the plug off in the intake if so you are in for some work and money!!!!! But do do them all at once if all the other starting and charging system is new might as well go all new for the glow plugs as well! Hope this helps!
Old 12-03-2011, 07:50 AM
I read some where that on this system if one is burned out none of them work. I have the same problem with mine. In a pinch you can manually cross the relay. I've replace six so far. The other ones under the turbo I havn't changed yet. I hope when I change the other two they work like they should. For now I just keep it plugged in. Good luck!
Old 12-13-2011, 04:03 PM
super easy to change like bend over said be careful not to break any pulling out. you can check them by removing connector on top of plug and with a test light hook to 12 volts and place on plug if it lights up its good if it doesnt its bad. i also like to put anti seize or white lithium on plugs when installing to keep from seizing for next time good luck
