new tow rig.. - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 04-17-2011, 06:07 AM
Send a message via AIM to baderic03
new tow rig..
so im picking up a 88-89 f350 4x4 use to be a wrecker auto 7.3 idi
floors are junk along with the whole cab i got a clean cab off a 90 ford f250 gas truck im goin to swap over
and i need to get the trans rebuilt only has reverse no foward gears
now some questions for you guys
how hard of a swap is it goin to be t swap over my gas cab for the diesel cab same generation truck except one is auto and one is a 5speed and as far as wiring the idi is it simple wiring for motor or goin to be a pain? i would like to keep my dash thats in my donor truck bc its a xlt lariat thats spotless and just change the colms over
thanks in advance
Old 04-17-2011, 04:03 PM
so what i have been reading on the cab swap says i cant use my factory dash in my donor truck thats gas is this true or not bc my dash is perfect along with my donor truck minus a title problem
my diesel is either a 88-89 my donor truck is a 90 gas truck and possibility??
and im just doin a cab swap so all i need to do is pull the four body mount bolts on the cab and swap them correct?
secound how much of a harness is there on 7.3 idi motor my body harness is the same i belive any way to rewire the diesel harness to work with my dash ?
Old 04-18-2011, 11:27 AM
Your going to run into a vin problem when swapping cabs. The correct (legal) way would be to title your truck with the cab that you would swap on. Therefore your 1 ton truck would then become a 3/4 ton truck, and you can run into problems when towing things (as you would appear over the limit).
I would use the diesel cluster just for the ease of that. Other than that, i'm not a wiring guy sorry man.
Old 04-18-2011, 11:58 AM
the reason this is all happening in the first place is bc i cant get a title to my 90 f250 so im getting the diesel and swaping everything over so i have a mint truck with a better motor and it will be auto
Old 04-19-2011, 06:50 AM
pics of my poor donor truck
