Question about EGT's - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 07-28-2007, 11:18 PM
I just installed a banks sidewinder kit on my nonturbo 93 F350 crewcab with 237,000 miles on it and the paper that came with it said to keep the EGT below 1050*f but on their site under tech info it said that you can run up to 1300*f with no ill effects so which one do I listen to?
I used the truck the day after the install to pull a 10'000 lb camper to the mountains. Although we never maid it due to the tranny going belly up I did get it under some pretty heavy load and saw the EGT's get no higher than 950*f and still feels a little lazy but still is not comparable to pre turbo and it don't matter how hard you push it this truck won't smoke. Can I change the timing and/or turn up the fuel anymore without damage?
I have noticed that a turbo truck and nonturbo truck don't use the same injectors or pump. What is the diff and should I consider a change?
I have been thinking about doing away with the clutch fan and going to electric fans to free up alot of power. Can I do this and still have enough cooling?
Last but not least the trans cooler is mounted on the hot side of the radiator and I have always mounted them on the cool side in my gassers, can anyone tell me if there is some magic reason for this?
Old 07-29-2007, 07:53 AM
im fat and ugly
i dont have a clue on the non turbos but heres a free bump
Old 07-29-2007, 08:18 AM
i don't know what the EGT range is for your setup. on the vehicles that come with one stock, don't go past 1300 degrees for prolonged periods (just a few seconds).
Old 07-30-2007, 01:18 AM
bump it up
Old 07-30-2007, 02:18 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Call Banks. It's his Sidewinder. He should know the average EGT range. (Don't call the techs...call Gale Jr. and get it from him. Though I bet he doesn't know.)
Old 02-16-2008, 03:13 PM
My Banks power pack kit said do not exceed 1200 egt.
Old 02-16-2008, 03:18 PM
1000 would be a good number. Putting a turbo on a higher compression motor makes the EGT's even that much more critical because the cylender pressure tends to create more heat in the cylenders too. They are netorious for melting down #7 if you push them too hard...
Old 02-16-2008, 03:21 PM
im not 2 sure bout non turbos but u would deff be safe to bump 1300 for sure i mean in short burst they can take alot
