Injection Pump help - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 5 Old 03-25-2011, 01:11 PM Thread Starter
Injection Pump help
how can i determine the condition of my inection pump on my '94 7.3L IDI factory turbo? is there any way of telling if it is the orginal or a reman?
Thanks
'94IDITurbo7.3L is offline
post #2 of 5 Old 03-25-2011, 01:31 PM
95powerstroke5spd's Avatar
Usually rebuilt pumps will have paint on some of the bolts on the pump. So they can tell if you have been into the pump if something went wrong.
1995 F250 Ext cab Long box 7.3 DI Turbo Diesel 5 spd 308,000 mile TS 6 position chip.....Is currently without an engine
1996 F250 Ext cab Long box 7.3 DI Turbo Diesel Auto 210,000 mile Stock except for the wheels.....Looks like a crushed beer can at the moment :/
2006 F250 Crew Cab Short box 6.0 DI Turbo Diesel Auto 5 spd on the column 218,000, EGR delete with up-pipes, FICM tuner, 285/70/17 Mickey Thompson Baja MTZ rubber,
95powerstroke5spd is offline
post #3 of 5 Old 03-25-2011, 02:08 PM Thread Starter
My pump does not have any bolts w/ paint on them. almost over night my MPG has gone from about 15-16 to less than 10. could this be from a bad IP? My tranny is shifting kind of late and i checked the TPS and it was good, just wondering if a worn IP could cause the TPS to give a good voltage reading but give the tranny the worng signals since the TPS is on the side of the IP. my engine has 200,000 miles on it and i am 3rd owner so no idea of IP history. i just replaced my injectors and i still get quite a bit of white smoke @ start up no-matter what engine temp, could this be worn IP?
Thanks
post #4 of 5 Old 03-25-2011, 03:13 PM
I dont see how all of a sudden the pump is worn out. Maybe the injector pump timing is off? The mounting bolts might have came loose? Just giving some ideas.
post #5 of 5 Old 03-25-2011, 04:09 PM Thread Starter
I have the motor manual for my engine and it tells that there is a metal badge on the turbos with info about the turbo and the manual says that the original turbo as a badge that is a certain color and the reman turbos have a different color so you can tell whether or not you have a original or reman. there is a badge on the side of the IP and i was wondering if that has the same type thing as the trubo badge for identification of original vs. reman? can the IP be tested anyway kind of like pop testing injectors. how do i go about adjusting the timing and which direction do u think i should go with the timing?
Thanks
