ford 7.3 don't want to start after warmed up. - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 07-23-2007, 10:56 AM
93 ford 7.3 starts good when cold, after it runs 30 minutes & it sits awhile it dosn't want to start with out a shot of starting fluid,( I have a switch so I can disconnect the glow plug heater) to avoid problems. It has new filter, new lift pump, new injectors, new injector pump, glow plug system works good. It runs great when started.
Any Ideas?
Thanks Dale
Old 07-23-2007, 11:03 AM
Powerstroke Techie
Could be timing. Who set it when you had the pump installed.
Old 07-23-2007, 11:06 AM
I did, set it by mark on pump and mark on mounting boss. it don't smok at all?
Old 07-23-2007, 11:08 AM
Powerstroke Techie
That mark is a starting point to set the timing. You should have it set by someone who has the tools to do it.
Old 07-23-2007, 11:21 AM
do you know first hand that if the timing is off a little it will cause this problem?
Thanks
dale
Old 07-23-2007, 11:35 AM
Powerstroke Techie
yes it will
Old 07-23-2007, 12:38 PM
Hey Thanks Bud, I'll give it a try.
Dale
Old 07-23-2007, 12:45 PM
Next time it doesn't want to start, take out the fuel filter and see if it is full of fuel. If not then fill it to the brim and try to start it. I had a similar problem with cold starts that turned out to be a leaking fuel line. Filling the filter helped it start right away and it would run and start fine, unless I let it sit for more than a day or two.
Old 07-23-2007, 01:02 PM
thanks
Dale
