Pretty sure I'm getting a good deal. - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 01-06-2011, 05:43 PM
Well tomorrow, if the guy shows up with the title, I will be buying a '92 CCLB 4x4 standard for 200 bucks. The only thing is it doesn't run, but hey for $200 i figure why not, everything else works.
Old 01-06-2011, 05:56 PM
Shade tree mechanic
Very cool. Do you know what is wrong with the motor? Is it fixable?
Old 01-06-2011, 08:12 PM
Well he said that he drove it to where it is now and parked it. Then the next morning he went to start it and had to remove the glow plugs and blow water out of the cylinders. I dont even know if that sounds right. So I will see when I get it.
Old 01-06-2011, 08:19 PM
It is possible for the blocks to cavitate so bad that it could... but either way IDI's arent super hard to find and you could always swap a obs 7.3 in, lots of motor options... good deal for a rolling chassis
Old 01-06-2011, 08:31 PM
What do you mean by the block cavitating?
Old 01-07-2011, 04:38 PM
the 7.3 IDI is a bored out 6.9 motor.. so the walls are even thinner and motors neglected without the proper SCA/DCA coolant additives or ELC coolant can break down and cavitate.. the vibrations that the diesel motors make with the high compression literally breaks down the walls in the cooling passages.. i hope that makes sense im explaining the best i know how. im no expert.. but ya.
Old 01-09-2011, 10:17 AM
Sounds like it to me
Sounds like a good deal to me. If you wind up with parts to sell, let me know. I've got a 1992 350 CCLB 4X4 auto
Old 01-10-2011, 12:22 PM
Wow. I had no idea about that at all, and yes it make sense thank you for the help. Well this is going to sound dumb but i would assume that means a whole new motor. And if so will a 7.3L turbo powerstroke bolt into that truck.
Old 01-10-2011, 12:24 PM
Its probably not going to be someting you want, but i will be trying to sell the mechanic's bed. It's white with at blue stripe down the middle. just FYI
Old 01-11-2011, 06:30 PM
Thanks for the heads up - don't need mechanics bed. Did you get the truck? What shape's the chassis in?
