temp gauge inop - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 07-05-2007, 03:43 PM
temp gauge inop
I just purchased a 94 e350 w/7.3 IDI engine. My temp gauge is not working. Can someone point me in the right direction? Where does the gauge pick up its reading from? Is there a way to test the gauge itself?
Cheers,
Peter
Old 07-05-2007, 04:07 PM
Im not quiet sure but someone will be along to help just giving you a bump
Old 07-08-2007, 01:40 PM
Thanks for the bump. Anyone know where to begin w/ this one?
Old 07-08-2007, 01:43 PM
ADMIN AND TECH
the sending unit for the gauge is screwed into the top of the water pump, unplug it and ground it to the engine , see if the gauge mioves , may have to cycle the key , then leave it disconnected to see if it moves , if the gauge doesnt do anything , your gauge is bad , if im not mistaken , its a red and white wire, whe n you ground it the gauge should top out
Old 07-08-2007, 02:33 PM
Thanks! I will try this. I hate driving anything w/o a temp gauge but especially an old diesel.
