IDI exhaust - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 64 Old 10-02-2010, 05:29 PM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
IDI exhaust
I was thinking about putting an exhaust on my 1990 7.3 IDI. I was thinking a dual 4in straight pipes to 6in tips. Would this cause any problems?
Thanks, Austin
Austin
1997 f250: mbrp 3in downpipe 4in side dump exhaust, diy 6637 intake, TW custom tuned 6pos chip, wicked wheel 2, rough country 4in lift, dana 60 swap, led dash lights, explorer overhead console, LED tail lights, dual trans coolers, SD fog lights, 08 rear diff cover, diy efuel, 20" racleline wheels with 35" firestone destination mt's,lots more little things
Nonturbo is offline
post #2 of 64 Old 10-03-2010, 01:42 PM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
Anybody got an opinion?
Austin
Nonturbo is offline
post #3 of 64 Old 10-03-2010, 01:51 PM
powerjokin 6.0's Avatar
It should sound good
2006 6.
powerjokin 6.0 is offline
post #4 of 64 Old 10-03-2010, 03:25 PM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
Thats what I was thinking. Hoping its slightly obnoxious.
Austin
Nonturbo is offline
post #5 of 64 Old 10-03-2010, 04:35 PM
kuntryquesttsi's Avatar
Are you doing duals out the back or off the the side? I want to roll coal on people behind me lol
kuntryquesttsi is offline
post #6 of 64 Old 10-03-2010, 04:44 PM
powerhoghp's Avatar
True duals or single back to duals?
powerhoghp is offline
post #7 of 64 Old 10-03-2010, 07:30 PM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
I'm planning on true duals out the back.
Austin
Nonturbo is offline
post #8 of 64 Old 10-03-2010, 07:54 PM
FordGuy100's Avatar
4" pipe is expensive.
I would just suffer and save for a turbo.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #9 of 64 Old 10-03-2010, 07:58 PM
FordGuy100's Avatar
OB has an add for an 088 (non gated) ATS turbo kit complete for 750 plus shipping.
-Justin-
post #10 of 64 Old 10-03-2010, 08:11 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Since its naturally aspirated, you aren't going to want to run 4". Especially if you do true duals. Your exhaust velocity is going to be very low and cause you to lose power in the lower RPM range. I would do maybe 3". And you are going to want a crossover in the pipe somewhere. You want the 2 banks to come together to help flow and scavenging. Whether that being just an x pipe or running the 2 together then splitting them right before the axle.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
