| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
Testing glowplug system
How do you test the glow plugs on these trucks?
BUMP BUMP BUMP i am looking for the same answer man. im about to just replace the GP and GPR
let me find the link!
Glow Plug / AIH Relay locations
alot of times its just the GP relay....highly recomend the stancor relay.......... |
well i knew that, is the IDI the same then????? if it is then i would had this job done a long time ago
dont know about the IDI... I'm pretty sure testing the GP would be done the same way...no more than GP cost for the IDI's, and easily accessable, depending on milage...I'd swap them out
With cd glow plugs (ie truck hasn't been run in 12+hours). Take an ohm reading of each plug. If they are less than 1 ohm you are good, if mote, replace.
Stancor relays are for powerstrokes, not IDI's |
glow plugs are good havent tested relay yet but truck starts right up when plugged in but has to crank a while when not
