IDI Glow Plug Relay - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 5 Old 09-02-2010, 09:26 PM Thread Starter
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
IDI Glow Plug Relay
Seems our GPR went out again with the plugs.
So instead of buying a replacement , is there an updated or upgrade to the relay on these idi engines? We have the relay with the square box underneath it.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #2 of 5 Old 09-03-2010, 08:18 AM
FordGuy100's Avatar
I heard the infamous black truck wont even turn over now?
As far as I know, stock relays are the only ones. We ought to wire it up so that the glow plugs wont kick off like normal, just change the post of the hot wire we ran to it.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #3 of 5 Old 09-09-2010, 09:12 PM
Country417's Avatar
I have a 93' IDI that is getting hard to start. One day I noticed that the wait to start light was not coming on but then it started working again later in the day, this has only happened one other time since but the truck is still hard to start. I say hard to start, it seems like it is not getting fuel fuel or something but everything I keep checking is showing me fuel getting everywhere it is supposed to. Could I be having the same problem? I had the head gaskets replaced not long ago and they replaced the wires and reconnected all of the glow plugs back up.
Thanks for the help.
Country417 is offline
post #4 of 5 Old 09-11-2010, 07:23 AM
ryandamo's Avatar
will the stancor relay that we use on powerstrokes work on the 7.3 idi? It looks like i can make it work on my 6.9 but i know the glow plug system is different on a 7.3 idi
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #5 of 5 Old 09-11-2010, 08:17 AM
FordGuy100's Avatar
I honestly dont know about the PSD controller.
Being the cheap bass turd that I am, I just wired my glow plugs to a manual switch. NAPA wanted like $150 for a controller. 10 bucks later I have a fail proof glow plug controller (my controller happens to be me counting, (1.2.3.4.5.6.7.8)
-Justin-
