Help! - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 06-03-2010, 07:18 AM
Help!
My truck will start fine the first start but after tht i can go start it again will crank forever and then once it finally starts it will rev up and down then eventually die then i need to start it agin and rev it for it to actually run. Anybody know what the problem could be?
Old 06-03-2010, 07:20 AM
i was told hard starts when hot,could be the injector O-rings?
Old 06-22-2010, 05:10 AM
reply
hey my names nick, i am having the same problem with my 89 7.3 IDI, im changing all the injection return hoses, fuel filter, injector o-rings and the caps that the return hoses connect to because the stall could be created from air getting into the fuel from dry rotting or cracks
Old 06-22-2010, 05:30 AM
What is your fuel guage reading? If less than or close to 1/4 tank its the fuel pickup tube. Otherwise, I am not certain.
Thad
