| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
OD Light Blinks intermittently
So I have had an intermittent issue with my E4OD going into a safe mode. The light starts blinking and the shifts are hard. What signals does the transmission get. Where is a good place to start testing signals? What is common with this symptom?
Could be a multitude of things. The best place to start is the FIPL (TPS on a gas engine). PRobably getting a bad signal or the FIPL is bad. Just a place to start. If you need help testing it let me know.
THad |
Yup could be something simple as mentioned above or it could be something way worse. How does yur tranny fluid smell?
The fipl is the sensor on the injection pump? I think its also called the potentiometer? I have replaced that twice. So I don't think that's it. What would you recommend next. The fluid doesn't smell burnt and doesn't have metal shavings in it. I was going to change the filter and fluid soon anyways since I just bought the truck. I was considering welding in a temperature sensor, but I don't think its overheating.
So i jumped the eec wires and got three codes.
97- E4OD OD cancel light circuit failure - Transmissions 23- Throttle sensor out of range or throttle set too high - TPS 62- this says circut to ground failure 3/2 or 4/3 and it also says, E4OD excessive converter clutch slippage - Transmissions Does anyone know the range that the potentiometer should read? |
1.1 idle to 4.3 at Wide open throttle
Thad |
Voltage is right. When I opened up the pan yesterday I found some loose valve body bolts. I tightened them up and welded in a temperature sensor. I haven't had the issue again. I have not pressure tested it but I am confident that that might have been some of the issue. I am going to run it a bit longer and see what it does. I will post back as soon as it comes up again.
Keep us posted.....I am interested. Where did you put the temp sensor?
Thad |
in the low part of the pan, where the drain plug is. I did it coming out towards the rear of the vehicle from that 4 inch by 4 inch sump area. Just welded in a 1/8 stainless bung. I just wanted to make sure it wouldn't interfere with anything or hang to low that it will get cut. So far i hit 180 in traffic on the highway. I haven't loaded it up much though. Any idea on operating range?
Thats fine for temps. I wouldnt let it get much over 205 or so before taking corrective action.
Have installed a auxillary oil cooler or do you just have the stock one? Permacool has some good choices for coolers. Once I put mine on I had no worries about temps! Thad |
