strange sound from exhaust - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 8 Old 04-22-2010, 06:25 AM Thread Starter
1990dieselguy's Avatar
my truck is making this sucking sound from the exhaust but it doesent effect how it runs i looked allover but could not find anything. so i thought i would post it here to see if anyone might know what it is. any help would be great thanks.
1990dieselguy is offline
post #2 of 8 Old 04-22-2010, 06:37 AM
symbols's Avatar
Is this when it's warming up? Is your truck turbo or naturally aspirated?
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #3 of 8 Old 04-22-2010, 06:43 AM
L.I.P.COLL320's Avatar
I am assuming your truck is a 1990 and not turbo, but on the turbo engines there is a flap just after the turbo that restricts the exhaust when the engine is under operating temp. When this flap is closed it makes what can sound like a sucking noise.
L.I.P.COLL320 is offline
post #4 of 8 Old 04-22-2010, 06:54 AM Thread Starter
it is non turbo and it does it all the time it is kinda like an old train sound
post #5 of 8 Old 04-22-2010, 07:22 AM
symbols's Avatar
I bet it's your air pump....
Jason
symbols is offline
post #6 of 8 Old 04-22-2010, 09:24 AM
FordGuy100's Avatar
IDI's dont have EBPV's. As far as air pump, are you refering to the vacuum pump? If its wooshing you would have decreased braking performance, I would think he would post something about that?
I crack the injector lines one at a time to see if a injector is making the noise. If you crack it and the engine starts to idle rough, and the noise is still there, its not that injector, and move on. I would also want to pull the valve covers and check all the rockers, might be a exhaust valve problem of some sort.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #7 of 8 Old 04-22-2010, 09:35 AM
symbols's Avatar
Yes, sorry I meant vacuum pump
Jason
symbols is offline
post #8 of 8 Old 04-24-2010, 07:35 PM Thread Starter
so today i took off the valve cover and all the vavles seem to be good as well as the springs. i dont think it is the injectors because it runs and starts great.
