rusted fuel lines, anyone replaced with rubber? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 5 Old 04-20-2010, 03:41 PM Thread Starter
hey guys have a 94 turbo idi and the rear fuel lines are rusted and starting to leak. Was wondering if anyone has ever replaced them with anything other than the $172 dollar dealer lines. Checked all the auto parts stores and no one has em. I was wondering if i could just run new ones with hose clamps and the right kinda of lines, or if there was too much pressure in the system. Have to do some work on both tanks and lines, and not trying to invest 800 dollars in parts.
thanks for you help
nik
nik1994 is offline
post #2 of 5 Old 04-21-2010, 07:56 AM
FordGuy100's Avatar
Which lines are you talking about? The hard metal lines going to the injectors? If so, you have to have metal lines, pressures are too high, and they have to be the same length of injection timing for each cylinder would be messed up. I've seen the hard lines for sale on the internet but forgot the site. They seemed to be $25 a line.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #3 of 5 Old 04-21-2010, 12:07 PM Thread Starter
Talking about lines from fuel tank switch to gas tank. Has rubber ends with metal line about 5 feet long between.
nik1994 is offline
post #4 of 5 Old 04-30-2010, 08:14 AM
m-hickey95's Avatar
I had the same problem on mine. The metal line has a hose on the end of it already, the real problem is those damn special Ford fittings. If anyone knows how to get rid of those, I am all ears. I just used generic metal line of the appropriate size, cut the ends off and attached the hose with a hose clamp. It has been awhile, but I believe I put a bit if a flair on the end of the line just so the hose had something to grab on to.
m-hickey95 is offline
post #5 of 5 Old 05-18-2010, 06:42 PM
Send a message via AIM to BadF250Boy99
a little late for this topic but NPD sells all the fuel lines with the correct fittings on them
they are a little pricey but they are good parts
BadF250Boy99
2001 Excursion limited 7.3 powerstroke
331,000 miles
BadF250Boy99 is offline
