Tranny question? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 3 Old 02-14-2010, 07:17 PM Thread Starter
Tranny question?
I have a 1992 F350 2WD SC DRW 5 speed 7.3L idi.reverse is out of it.
MYquestion is, is there a 6 speed transmission that will bolt on to this truck. I have 4.10 gears and would love an extra gear for the highway.Thanks.
gcrichfi is offline
post #2 of 3 Old 02-14-2010, 07:45 PM
FordGuy100's Avatar
Nope, not without a LOT of modification. I know of only one guy putting a ZF-6 speed into an IDI equiped truck, and he was a fabricator.
If you would like another gear, a external overdrive like a gear venders should do the trick.
By the sounds of it, your tranny needs to be gone through, and some synchros need to be changed.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #3 of 3 Old 02-15-2010, 05:33 PM Thread Starter
Well I have another tranny already for it but if I could put a differant tranny in it I was goin to but thanks for the info. More work than I am willing to put in it sounds like.
gcrichfi is offline
