| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
axle swap ?
Anyone swapped out ttb setup for 99-04 psd axles bought a set to fix 88 3/4 tons problems thought would see if anyone else has tried and what problems arose along the way thanks. Rick
Rear will drop in if the pad centers are the same as a OBS. the front will give you some problems with the axle pad centers..
![]() bumping back up anyone else do it? I got the axels and going to try it
Front is going to be different. Not to mention wheel bolt pattern is different. I think they use longer front springs. Fabrication is required.
