'93 F350 Blue Smoke - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 12-22-2009, 09:22 AM
'93 F350 Blue Smoke
I have a 1993 7.3 non turbo motor in my dump. I just bought the truck, it has only 55k miles on it. It idles and drives fine. However, it tends to blow some blue smoke until it warms up and sometimes for longer. What can i do to fix it??
Old 12-22-2009, 09:32 AM
you may need to put in new glowplugs, on these older motors its common to smoke a little at start up, as long as it starts without any problems i wouldn't worry about it. if it has trouble starting in the cold, then you should probably look into replacing them. if you havent already, i would to go oilburners.net and join over there too, its a very active forum for the old idi engines.
Old 01-14-2010, 03:11 PM
every diesel retards timing on cold starts which causes smoking and loping sound. so it is normal for it to do this
Old 01-14-2010, 03:55 PM
yea thanks.. its been sitting a while n ive been running it alot and now it barely smokes.. It definately needs glow plugs though bc its a ***** to start.. i have the same truck but a '94 and it's alot easier to start..Does anyone know the best glow plugs to get?
Old 01-14-2010, 05:29 PM
Bosch seems to work pretty well for me..... I started it w/o a block heater after sitting all night in below freezing temps and she did just fine. I was quite surprised, actually!
