front fuel tank??? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 03-12-2007, 06:29 PM
Send a message via MSN to 04mach1
front fuel tank???
well im sure everyone has read about my fuel problems and stuff with my truck..
well i found my leak and its the hard lines ontop the inake that go to the injectors. i found 2 of them leaking.
so i tried to tighten and they wont stop. so i purchased all new lines.. BUT this isnt te purpose of this post.
the purpose is that when i switch to my front fuel tank the motor starts to idle wierd and the diesel sounds goes away also when you hit the gas pedal it kinda chugs up to the rpms..
also it blows white/bueish smoke out of the exhaust like ALOT OF IT.. my uncle works for greyhound and he said to just let it run since its like there is water/ something in the fuel... im kinda scared since in a gas motor white/blue smoke is oil burning which means its not around the pistons rings and not lubing the motor..
i dont want the thing to blow up so i haven ran it on the front tank...
any ideas guys????
thanks
" the noob "
Old 03-12-2007, 06:46 PM
Best bet would be to drop the tank out and clean it up good, put it back in and see what happens, If you don't use the tank often, you may have a build up of water ( condensation ) and possibly algae in the tank, best to get both out.
Gord.
Old 03-13-2007, 10:53 AM
95% of the time i run on the front only and leave the back full " incase " i cant find a diesel station around..
( i do alot of travelling )
so im sure its not condensation. i used it the day my tranny went and everything. the lines were off the tank the exact same amount of time and everything.
so i dunno...
Old 03-13-2007, 11:00 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
You've got poo-poo in your tank, clogging your filter and the pickup sock. Drop the tank and siffen off the fuel into a BIG GLASS bottle. You'll pee yourself when you see all the crap that was in there.
Old 03-13-2007, 10:22 PM
You could also have air comeing into the system from the line connections.
Gord.
Old 03-14-2007, 06:37 AM
hmmm well i guess im going to have to drop it and figure out what is wrong and go from there, atleast now i have a couple options of what it could be so i can check those out..
thanks guys!
Old 03-14-2007, 06:50 AM
Keep us posted on how you make out.
Gord.
Old 03-14-2007, 06:51 AM
sure will
thanks from
" the diesel noobie "
Old 03-15-2007, 06:54 PM
any ideas guys????
thanks
" the noob "
the smoke issue sounds like unburned fuel no big worry maybe you have inop glow plugs? mine havn't worked since I bought my truck in 1999, but I live in a warm climate so I can deal with it.
if your havine issues switching to front tank I had same issues, I solved them junking the ford system and installed my own. I found the the factory plastic fuel pickup in both tanks on my truck were broken and floating around inside my tanks, I ditched all that junk, look in my pics to see how I solved the problem
Old 03-16-2007, 01:43 AM
so instead of your fuel being pumped outt the top you have it coming out the bottom of the tank? wont a bunhc of junk come out with it??
