Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Trannie Problems
Old 01-28-2006, 01:31 PM
86hatch 86hatch is offline
Tranny question
OK I have searched around and havent seen this yet. I have a 99 cc F350 4x4 with 130xxx miles and it did this for the second time today. Under a heavy load when pullin the trans starts pukeing fluid beepbeepbeepbeep near til its empty (like 12qts) today. Now has a lil burnt smell but with fresh fluid away I go and still pulls fine. Oh and when it was low the od light on the shifter blinks and the tc doesnt unlock. I put fluid in and turned the truck off and started back and no light light and the tc works fine. I thinking the tc might be shucked or maybe a clutch pack. Im not really sure because Im not firmilliar with an auto trans. Any help will be appreciated!
Thanks in advance,
Jeremy
Old 01-28-2006, 01:33 PM
mschn99 mschn99 is offline
Banished
where was the fluid coming out???? front of the trans, or more center to rear of the trans???
Old 01-29-2006, 08:56 PM
Its pukeing out of what looks like a vent tube. Also it only does it under 45 mins. of heavily loaded pulling.
Old 01-29-2006, 09:20 PM
Banished
that usually indicates an overheat condition, and the first thing i would do is add on a secondary trans cooler. it is tough to say what is causing your problem...but chips increase line pressure, and therefore need more cooling....and if you have a trans problem, you build more friction....and thus tend to overheat the fluid also.....you could have a fan clutch not working properly....but usually your engine temp would be high also......im thinking that you may have either a plugged trans cooler or an internal trans problem, but the extra cooler will not hurt anything and is worth a try.......
Old 01-30-2006, 05:41 AM
mgwerks mgwerks is offline
And put a tranny temp gauge on it!
Old 01-30-2006, 12:15 PM
Thanks fellas. I just happen to have a trans temp gauge for my camaro Im not using. So what is a safe trans temmp anyway?
Jeremy
Old 01-30-2006, 02:19 PM
purduefarmboy460 purduefarmboy460 is offline
Send a message via AIM to purduefarmboy460
The lower the better, right now being cold, mine barely moves! I have never seen mine get much over 200 when pulling, well, alot of weight...let's see 500 bushels of wet corn @ 60 lbs/bu.
anyone else know a average tranny temp?
Old 01-30-2006, 03:15 PM
Banished
Jeremy
it all depends on where you put your temp gauge......before or after the cooler. before will give you a better indication of the temp the trans is operating, after will let you know good, cool fluid is getting to the trans......
Old 01-30-2006, 05:08 PM
pro99line pro99line is offline
Around 180-220 would be a normal operating range from experience. Ofcourse since the trans fluid goes through the coller on the radiator is is going to be close to the water temp give or take. I would not go over 220 really. We do not go over 220 and that is with a 3500 stall converter.
Old 01-31-2006, 03:39 AM
stomper2 stomper2 is offline
What about mounting it right in the tranny pan, good or bad idea?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
