Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Trannie Problems
Old 06-17-2006, 09:43 PM
jrs jrs is offline
6 Speed Manual Trans
I just bought an '01 F350 supposedly bone stock but just had a new clutch put in. In both 1st and 2nd gear at low speed there is a lot of gear rattle from the transmission. Is this normal for the 6 speeds? Oh, truck has 165K on it. (My previous experience is only with diesels and automatics.)
Old 06-18-2006, 07:12 AM
mschn99 mschn99 is offline
Banished
when you say rattle....does it sound like one little marble is kinda bouncing around in there??
Old 06-18-2006, 08:40 AM
jrs jrs is offline
Yes, your marble analogy is pretty good. It's only at low motor rpm, goes away above maybe 16 - 1700 rpm.
Old 06-18-2006, 08:48 AM
Banished
it could be a lot of things then. the imput shaft bearing could be going, a syncro could be a little sloppy, or the throughout bearing could be grumbling.
when you had the trans out for the clutch, did you replace the pilot bearing and throughout bearing???
did the imput shaft have any signs of scarring were it rides in the pilot bearing???
have you tried servicing the fluid to see if that will make it quieter??
Old 06-18-2006, 10:25 AM
jrs jrs is offline
New throughout bearing, don't know about the pilot bearing but I suspect not. I will certainly try the fluid service. thanks.
Old 06-18-2006, 11:02 AM
overl0rd overl0rd is offline
Send a message via ICQ to overl0rd Send a message via AIM to overl0rd
Also, ZF trannys are notorious for noise, being that you're used to autos you could be a little more sensitive to driveline noise. Keep an eye out for any metal shavings/particles when you service the fluid, if it's clean I wouldn't think much more of it. Was the clutch professionally installed? If it was I would think they'd replace the pilot bearing.
Old 06-18-2006, 02:56 PM
jrs jrs is offline
Thanks. I'll do a fluid change next week and keep a close eye on what comes out.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
