- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
trans question
I have a 99 F-250 with auto. When I put it in 1 it will idle all day but if I try to move it will go about 10 feet and shut the motor off. It will start right up and do it again. Does fine in 2 and D. Ford had no idea.
Next, every once in a while when I am driving down the road the speedometer will stop working and a few seconds later the od light will start flashing. Any where from 5 to 15 minutes later the speedo will start working and a few seconds later the od light will stop flashing. Any idea anyone Thanks Clancy |
| Sponsored Links |
trans
Marc. A polite correction. The 4r100 does not take off in 2nd unless you select 2. It always takes off in first in the od selection. The reason the engine dies in manual 1 is because of a cross leak in the pump caused by high line pressure when man 1 is selected. When the pump is perfect, this does not happen, but with time and heat the pump warps and causes these cross leaks. The lock up valve is in the pump and this crossleak causes the valve to move and partially apply the lockup clutch, sometimes lugging the eng and sometimes killing it. Sometimes the converter itself can cause this, hence I always replace them both. Preston |
That's why I said " a polite correction " . He obviously know a lot about these vehicles. Preston
| Sponsored Links |
