- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Overdrive light
I have a 99 psd and it has 60,000 miles on it. The overdrive function
has not worked for a year. When I first bought the truck it only worked when the transmission was in park. Now it does not work at all, and the light never comes on is this a problem ??? |
| Sponsored Links |
OD light
I think it the problem is in the wires, it use to work when the truck was in park but now not at all. The torque converter was replaced a year a go under warrenty and I am not sure if was working before that because I don't tow with the truck so I never have needed to use the switch.Thanks for the help |
Cobrajet, the od light has nothing to do with the converter, it's for turning od off and on. It does need to be fixed because that light is teh emergency warning light for a trans malfuction. If it's not working, you could have a minor trans problem that turned into a big one. The shifter with wire is around $65 at Ford. You can change it yourself. About an hour. I assume from your handle you own a cobrajet. Had a 69 428 once myself. Preston |
YES, you should be concernd. Would you drive a vehicle without a working temp guage or idiot light. One overheat and you've wasted an engine. The od light on the end of the shifter also serves as a warning light for your transmission. When the computer sees something wrong, it starts flashing the light, gives you a warning. If you never see this light flashing and continue to drive, you could cause serious damage to your trans. Granted there are some thing that will turn the light to flashing that will not cause serious damage but I want to know as soon as possible. Your problem could be a burnt out light in the end of the shifter but most likely a wire rubbed into at the steering column. Most any trans shop shoul be able to fis it for you for around $125 to $ 175 depending on labor rates. Preston |
No O/D lite only in drive
I think I know where to look now, so thank's, maybe my problem will help someone elses diagnosis. O/D lite and lock out will not work on my truck in drive, works ok in any other position, and will stay locked out if I push the button in another gear then shift to drive but I have to shift back to a lower gear to turn it off. I did not know the O/D lite is also an idiot lite, so this idiot will be checking the wires soon, thankyou for the info |
thanks ipz2222
turned out nothing rubbed through but one of those tiny wires was broken inside the insulation. thank you again for the help |
| Sponsored Links |
