Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Motor Problems
Old 01-19-2006, 08:29 PM
97f350 97f350 is offline
Fuel Smell
Have a fuel smell in the cab of my 97 F350, any ideas on where to start looking????
Old 01-20-2006, 12:26 PM
BIGGTRUCK78 BIGGTRUCK78 is offline
Try Looking At The Injector Pump They Like To Leak There. The Seal Goes Bad Sometimes.
Old 01-26-2006, 05:09 AM
LS1powerhouse02 LS1powerhouse02 is offline
we had a strong diesel smell in our truck too....there is apparently a "water/fuel seperator" that might need to be replaced. We replaced ours and it took care of the smell. Good luck!
Brent
Old 01-31-2006, 04:09 AM
Star Gazer Star Gazer is offline
how to get rid of diesel smell?
I had the fuel filter come loose and leak fuel. Some got splattered on the hood and in the insulation material and it smells pretty bad after I drive for a while. When sitting overnight there is no smell when I first open it up.
Is there any type of product that will neutralize the smell? I imagine as it gets warmer it is infiltrating inside and I have a 3000 mile trip to make in a few weeks and this would make the trip seem long and very unpleasant.
Thanks,
Dean
Old 01-31-2006, 05:13 AM
mschn99 mschn99 is offline
Banished
Thanks,
Dean
engine de-greaser and a pressure washer at a car wash would be my reccomendation.........
Old 01-31-2006, 07:03 AM
Sounds like the best way.
Would this be any different than doing a car? I assume have it running and lightly go over the engine to wash off the Gunk?
Old 01-31-2006, 07:14 AM
Banished
you can blast the heck out of it, just dont spray directly intot he air intake. there are not plugs or wires to foul on a diesel, so there is really nothing to hurt, but yes, i would keep it running
Old 01-31-2006, 07:40 AM
pro99line pro99line is offline
Have it running? A diesel is not the same as a gasoline motor in the fact if the motor is hot and you spray cold water on the heads you take a chance of cracking them?
Old 01-31-2006, 09:22 AM
Banished
ive blown off and seen blown off more motors than i can count, and all of them were running. common sense says you dont spray the exhaust manifolds and such with direct water, but the fact that it is running does not make a difference, in fact, the head will be slightly hotter right after shut down so it would have a higher chance of damage.
Old 01-31-2006, 09:32 AM
Ok. Thanks. I guess it is just kinda one of those old wise tails then. I have just always followed that rule and made sure the motor was cold before spraying it. I have never known anyone to do it while running but now you have confirmed it is ok so I now feel I have the option to spray it while running. I also wanted to add that Castrol Degreaser in the purple bottle is awesome at cleaning grease and oil off of a motor. I mean this stuff is great.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
