Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Motor Problems
Old 01-15-2006, 06:49 PM
BIGGTRUCK78 BIGGTRUCK78 is offline
'99 sd warmup valve
i have a early 99 the warm up valve shuts while i drive down the road. untill i push on the throttle it opens for a while then closes again. it is driven me nuts. any fixes out there. i want to pull the turbo off and remove it all toghter. that is a last resort.
Old 01-18-2006, 09:21 AM
Ramsmoker Ramsmoker is offline
Powerstroke Techie
warmup valve
I don't know the answer and have seen other people with the same. You can reach down to the front side of the pedistal and flip the latch and unplug it or wire up the converter lock and warmup valve together as an exhaust brake. Take a look at the sketch I attatched. This is how I run mine. This can be converted to work without the switchs on the brake and throttle. I'm just excessive compusive.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
