Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Motor Problems
Old 07-05-2008, 09:36 AM
h2odrx h2odrx is offline
runs rough when floored.
It has only done this to me twice, yesterday I pulled off from a light and got up to 45, I don't think I was on it real hard but it started acting like it was out of fuel? it then died and I pulled over and it fired right up and was ok. today I pulled out on to the road and let into it and it shifted from first to second and then went to 2500 or better and would not shift when it did it just started slowing down and running rough? It did not cut off and was idling rough then smoved out and away I went? Anybody help the new PSD owner out?
Old 07-05-2008, 09:59 AM
SCUFFY828 SCUFFY828 is offline
SUPERDUTY GURU
sounds like fuel pressure to me , make sure oil is full also and in good shape , run a fuel pressure test and see what it says , needs to be at 45 at idle and climb up as you load the truck
Old 07-05-2008, 05:42 PM
should I shim the FPR? Who has an low dollar gauge? Oil looks good I think it was changed before I got it, I plan on changing it in a couple hundred miles.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
