Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Motor Problems
Old 07-02-2008, 12:20 AM
CsChuck14 CsChuck14 is offline
lopey idle at SOME starts
ok, first post, but ive been looking around for someone with this problem and cant find anything. First off i live in alabama and the temp has been around 80-90 during mid day. usually when i go out to my 97 psd in the morning and crank it most of the time i can count on it to start and immediatley idle like a 1969 dodge charger with a lopey drag cam. Then i press the pedal a little, and get it to idle steady at about 1.2k RPMs for about 4 to 5 seconds, any less and it will go back to lopey idle. and after i do it for about 5 seconds and let off the rpms drop and it "chugs" at about 700 to 750 rpms then rises a little and smooths out. i then usually drive away and its fine. Then i park. i have parked for 3 hours, started and it was fine but i have also stopped to get gas while the engine was warm and when i started 4 mins later it did it. it seems very random and i only could guess that its got something to do with a sensor or the computer, or dirty fuel/air filter, which im going to change out tom to see if that does it. thanks for the help.
Old 07-02-2008, 03:46 AM
twildman twildman is offline
Unplug your ICP sensor and see if it continues to do it, you will get a CEL but don't worry about that.
Also what oil are you running and when was it changed last and is it full?
Old 07-05-2008, 09:45 AM
h2odrx h2odrx is offline
so lopey idle is oil presure related?
Old 07-05-2008, 06:19 PM
bryan.d bryan.d is offline
Here is for ya. I have been having a similar problem.
Old 07-05-2008, 06:32 PM
planeoldguy planeoldguy is offline
I've had a small rump rump thing for the first 10 seconds or so since getting the new HPOP, nothing extreme though.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
