Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Motor Problems
  #21 (permalink)
Old 07-02-2008, 07:07 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
AE has a universal for most/all makes, but like adrian said it is up there in price.
  #22 (permalink)
Old 07-02-2008, 09:51 PM
sevenmalards sevenmalards is offline
Lets get ready to take em
Yep, better over charge the first few customers Scott, to recover the investment quickly!
  #23 (permalink)
Old 07-09-2008, 12:17 PM
I finally used my AE program today and I did the buzz test and cylinder contribution test and they both would not complete. They both said "test failed" do I have to be driving to do these tests?
I'll tell you one thing: The AE does so many things I felt like a
but it was cool to go through and test sensors while it was running.
Do they offer classes on how to learn this stuff?
  #24 (permalink)
Old 07-09-2008, 12:56 PM
no you do not need to be driving. The buzz test you will need the key on but engine off, the contribution test the motor has to be running.
If they continue to fail you do have a problem. Is it throwing any codes when it says "test failed"
  #25 (permalink)
Old 07-09-2008, 01:42 PM
How long does the contribution test take?
It has a bunch of electrical fault codes, battery voltage, and it threw a C (chassis code) that it said was unreadable
  #26 (permalink)
Old 07-09-2008, 03:38 PM
the contribution test takes about 2 minutes. not sure though, I have never timed it.. I would double check your batteries, and cables also.
  #27 (permalink)
Old 07-09-2008, 09:41 PM
It said my batteries were low voltage
  #28 (permalink)
Old 07-10-2008, 07:25 AM
Might want to have a load test done on the batteries to make sure they are still good.
  #29 (permalink)
Old 07-10-2008, 01:41 PM
I already know the pass. side one is bad. I've just been milking it along.
Time for new ones?
Does it make that much difference?
  #30 (permalink)
Old 08-07-2008, 05:54 PM
Anthony M Anthony M is offline
there are a set of wires inside valve covers. you will see a plug on outside of valve cover. another plug matches on inside cover. these plugs fail over time and become loose, let oil get into plug, cause electrical failure to injectors, therefore you get a code for the IDM but that is not the problem. i just replaced the inner set of wires and valve cover gaskets. you will need both to fix problem.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
