Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 03-18-2008, 10:46 AM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
No Start..
Ok I need some help with this one. My rig keeps giving me fits.
It is back to the no start crap which last time lead me to the IPR (and I swear if it is the ipr again I will light a stick of dynomight and blow this to pieces.....)
I have a short somewhere and it has something to do with the fuel system. when it goes on this no start spree the fuel pump relay will repetedly click under the dash.
It's not the icp, fuel heater, or IPR (I pray cause it is brand new!) I have checked the fuel pump harness under the truck for loose broken connections etc...
Would the IDM be causing this to happen sporadically? Could a bad alternator short out the fuel system? I don't know what is causing this. Once it finally does start it runs fine. no problems at all, but you have to "play" with it to eventually start it.
any ideas??????
Old 03-18-2008, 10:49 AM
Banshee34 Banshee34 is offline
Pay it Forward!
That sucks JW!!!
Old 03-18-2008, 10:58 AM
HappeetxnR.N. HappeetxnR.N. is offline
9/11 Have U Forgotten?
Have you visually checked the wires in the engine compartment for any nicks or scorch marks? Double checked all of the connections and so forth? Sounds like you have checked everything else, and I don't know enough about the IDM to comment on that.
Craig
Old 03-18-2008, 12:52 PM
man Craig I have checked everything twice..... I don't know what to check anymore....
Old 03-18-2008, 12:55 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
Have you replaced the relay? Also, a bad ground could give you fits, like that.
Old 03-18-2008, 12:56 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Hmm any codes?
Old 03-18-2008, 01:00 PM
It's raining down there right? Any chance water / moisture is getting into the PCM?
Craig
Old 03-18-2008, 01:20 PM
checked and swapped/replaced relays. Have checked grounds but will double check.
Originally Posted by vitalidle View Post
Hmm any codes?
no codes
Craig
I don't believe so. everytime it has done it it has been dry...
Old 03-18-2008, 02:03 PM
Man John the best advice I can give you is to talk to Scott.
Old 03-18-2008, 07:07 PM
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
