Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-19-2007, 09:20 PM
tbird tbird is offline
Exhaust pressure sensor question
I had some exhaust pressure sensor codes and boost was down from max about 6-7 psi. Before I replaced it, with key on engine off ,streaming data showed 16psi exhuast pressure. After I replaced it I have 14.1psi exhaust.
Same #s when idling. So im not sure if the sensor works in absolute pressure or relative. If absolute than 14.1 would be close to atmospheric pressure.
So I did some testing. If I get boost up to about 15psi the exhaust side only goes up 3 psi. If I remember correctly in the past if I was boosting 15psi the exhaust pressure was in the 30 psi range.
Any input appreciated
Old 10-19-2007, 09:26 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
You could try cleaning it first. Here is a good writeup Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old 10-30-2007, 10:06 AM
thanks for the help vitalidle, pulled the backpressure tube and oh looky , it had a hole in it . Got some flare unions and nuts and bent up a new section where the hole was and walla, it works now. Oh yeh, I cleaned it out too and there was a lot of junk that came out but it wasnt plugged.
Also found a boost leak where the line for my boost gauge hooks in so I believe that is why the boost is lower than it should. Still got fix this to prove it out.
Old 10-30-2007, 02:19 PM
Good news hope you get everthing worked out!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
