Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 08-08-2007, 01:06 AM
randalst randalst is offline
Send a message via MSN to randalst
extremely rough idle
ok this is my situation i was entering on to the highway and while on the entrance ramp i suddenly lost some power so i pulled over and when i slowed down enough to where my rpms were about at the idleing range my truck just started to shake vigoriously and also started makeing lots of noise like it was running on 5 cylinders so i took it into a diesel and import shop and they put a scanner on it and he said that my oil pressure was speratic and i need a new oil pressure regulator would an oil pressure regulator cause my truck to shake and make loud noises as if it is missfireing i called a ford dealer and they said that they had an oil pressure switch is that another name for the oil pressure regulator???? the part will cost me about 35$ (i already replaced the cps and checked all the uvc's.) also my service engine soon light is on any reply would be greatly apreciated
Old 08-08-2007, 03:59 AM
SCUFFY828 SCUFFY828 is offline
FORD MASTER DIESEL TECH
i would like to know what code is in it , that would help, if the light is on , there is a code there
Old 08-09-2007, 06:34 PM
dragrcr1005 dragrcr1005 is offline
i second that, get the code and it will be easier to figure out the problem. is the truck a manual trans or auto????
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
