Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Motor Problems
  #11 (permalink)
Old 05-07-2007, 03:34 AM
ksu_cowboy ksu_cowboy is offline
Sparatic Check Engine light and Loss Power
Not only did I have a fuel leak, but starting getting a sparatic check engine light and loss power. Went ahead and replaced fuel pump (removed turbo to do this, replace four fuel lines attached or near pump and banjo seals (gaskets). Still getting the check engine light and loss of power. Haven't driven, but maybe 8 miles since I replaced the pump. Could air in system, be part of this problem? Should have I have somebody read the code generated by the check engine light? Also does anybody know anything about the automatic hubs on the four wheel drive? After using four wheel drive they don't always disengage or sometimes re-engage and I hear a clicking noise when driving.
  #12 (permalink)
Old 06-10-2007, 09:23 PM
Mavsps Mavsps is offline
I have the same problem, I cant find a yellow handle on the back of the housing, where is the drain plug
  #13 (permalink)
Old 06-11-2007, 07:42 AM
Turbodude Turbodude is offline
Nuckin' Futz
its not on the back of the housing...its right on the front...stand at the front of the vehicle and look at the fuel filter bowl...on the left hand side (passenger) you will see a small yellow tab close to the glow plug relay...it should be pointing right at you....take it and turn it toward the glow plug relay to open it....you may need to pop the cap off so that there isn't a vacuum inside the bowl.
  #14 (permalink)
Old 06-29-2008, 07:25 PM
Cowboy777 Cowboy777 is offline
Fuel leak on 99 7.3 liter power stroke
I don't know if i can help ya any, but the main reason I stumbled upon this,is Ive got a leak on a 7.3 liter f250 and it is leaking around some kind of yellow valve of some kind,that is on the backside left of the filter housing, I dont know how to repair,any help would be appreciated.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
