- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
99 powerstroke has rough idle
99 ford f-350 crew cab 4x4 auto has rough idle in park,
seems to be missing truck is bone stock with 216,000 miles on it, please help dont know what to do. thanks guys. wolfeman1973 |
| Sponsored Links |
reply to rough idle
my powerstroke does not run any better in gear or when it is warm, it blows no smoke at all even in a cold morning 20 degrees, i dont know how to pull any codes what kind of tool do you use to do this ? p.s. can you tell im new to this im very mechanically inclined though . thanks guys for the help, its very appreciated. wolfeman1973 |
you will need to pay someone to pull the codes....or buy an OBD2 code reader to do it yourself and see what, if anything is there......there are a lot of things that can cause a rough idle or a miss on these.....and without some info it is virtually impossible for me....without the truck in front of me.....to figure it out........Marc
you know....one thing to check.....let it idle when its acting up....then immediately shut it down and check the oil level in the high pressure resevour. there is a plug on it....its the thing just in front of the fuel filter housing......this could be a low pressure oil pump problem........its just a thoght and codes would help more.....Marc
pulling codes (what does this mean)
A blown or missing KAM fuse will also give that code. Check the fuses in the fuse box by the master cylinder under the hood.
| Sponsored Links |
