- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
overhead
i was wondering if you had to get an overhead done like you do on a big rig after 100k? also how often would you recomend getting a tune up
| Sponsored Links |
every 4-5k......change oil, rotate tires, check tire pressures and air filter every 15k.......fuel filter....if your doing your own services.....drain all the powersteering fluid out of the resevour (just disconnect a cooler line at the cooler)....let it drain out and refill..... every 30k.....auto trans service, coolant service if its green coolant, service t-case on 4x4, powersteering service if you have your services done every60k......service coolant if its gold every 2 years.....change brake fluid 100k.....change serp belt and check pulleys, service manual trans, service rear diff, service front diff if 4x4 is used often |
thanks alot, i appreciate it. that really helps because i don't have an owners manual i bought the truck used.
| Sponsored Links |
