Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 7.3 Motor Problems
Old 02-17-2006, 10:15 PM
crazyfool502 crazyfool502 is offline
Angry sluggish on hills?
i recently went to pa to pick up a car and on the way back i noticed that the truck was running sluggish on the hills in wv! if the cruise was set it would run up the hills like a raped ape but the check engine light would also come on until i topped the hill any idea? it is a 99 7.3 six speed i didnt know if this makes a difference
Old 06-22-2006, 05:27 AM
worksontrucks worksontrucks is offline
check engine light
your cam positioning sensor is going bad. when i went out to tennessee back in Feb. from north carolina, my 99 psd did the same thing, and if i put it under a real load uphill it would studder or missfire. i had the code read at autozone and it came up with cam positioning sensor. its located right under your water pump and takes about 5 minutes to install. they run about $120 bucks and are easy do. by the way my truck did it when it started snowing and i was running empty bed. so don't feel that bad, you were towing a car.
Old 06-22-2006, 06:13 AM
mschn99 mschn99 is offline
Banished
Whoa, whoa........that is NOT typical cam sensor failure........i would highly doubt that is the issue.....
Get the code and get back to us man......ill figure it out from there.....Marc
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
